bigbadmiker
Hi,
I need some professional help with my MK2 cab. There is feedback coming from my speakers even when the sound is off. It sounds like a high pitched hiss. I messed around with the speaker wires but that didn't help.
Also, I've adjusted my monitor as best as I could, but there seems to be a problem with the vertical adjustment. I can't get it to increase enough. There's about an inch at the bottom of the screen that I can't get it to reach. When I adjust the v-size, it increases to a point and then starts to decrease. I'm not sure if this is normal. Here's some pictures. I've also got some issue with lines in the screen at the top, but most of them go away after a few minutes of being on. You can see the green line at the bottom of screen and at the top in some of the pictures.
Any advice is appreciated. Thanks.
http://s1012.photobucket.com/albums/af248/bigbadmiker/
