Jon Hughes
There are differences on the NBA sound board (meant for the T-unit) to the standard Mortal Kombat sound board. Firstly the power amp connected to the large aluminium heat sink is larger on the NBA board and is fixed with 2 bolts through the amp to the sink. The Mortal Kombat sound board has a smaller amp connected by a single bolt. Secondly some of the custom chips are directly soldered to the NBA sound board, whereas they're located in dual in line sockets on the original Mortal Kombat sound board. That's what I've noticed so far. To be honest you can swap the EPROMS from both boards over and it makes no difference - both work fine (with the correct ROM set) irrespective of what board you connect to. You will need a different power cables for the Y-unit & T-unit, one end is the same on both power cables. The other end, if memory serves, is 8 pin on the Y-unit and 9 pin on the T-unit.
