MK pcb in a MK3 cab
HighScoreSaves
Donor 7 years: 2013-2019
Blaine, Minnesota
Ok, I have read some posts that yes, it can be done.
Trying to narrow it down and ask how?
I have a MK3 running in a MK2 cab. Works fine.
I know there is a CPU and Soundboard for MK, with the power and data cable. They are there.
I see how the CPU connects to the JAMMA harness, but the kick harness is larger for the MK3 than the headers on the MK1 pcb...
What am I missing?
The easiest way is to have a T-Unit version of MK which uses the same kick harness as MK II and III. I think it was with version 5.0 that Midway switched to using the T-Unit hardware for MK and they certainly don't seem as common as the Y-Unit pcb's.
