MJ Moonwalker cp measurements
hell_rod
TORONTO, Ontario
I just picked up an original Moonwalker cabinet that had been converted a couple of different times by the looks of it. Original control panel is gone. Does anyone have the measurements and button layout? Or can do a trace?
Thanks!
Moonwalker control panel dimensions
Hi - did you ever get the measurements on this? I'm looking to do exactly the same and need to build one from scratch. Thanks!
I just picked up a Moonwalker cabinet... it has been converted to an Area 51 and when I open up the control panel I can see the original holes for Moonwalker controls along with a few other extra holes as this game has probably been converted a couple of times.
I need about a week if you'd like a trace or stencil you want me to mail to you. If you want some basic measurements I could probably get that Friday.
If you're in no hurry in a few weeks I should have it in EPS on illustrator as I'm getting some custom art done for my cabinet.
Thanks! That would be awesome. An EPS would be ideal.
There seem to be a few styles kicking around - mine is like this: https://images.offerup.com/XUudTPLR...800/7ac5/7ac515f6be994e0081d35b7f7617a512.jpg
Yours?
And tell me about your custom artwork - for Moonwalker or something else?
thanks for the help!!
Yup that's the one. Same body style. Originally I picked up this Area 51 to be my 3 player cab for my battletoads. But now that I figured out it was a Sega Moonwalker I'm having trouble deciding should I restore the Moonwalker or do the battletoads. The custom artwork was going to be for battletoads. I'll let you know as soon as I get it mocked up.
Nice. Much appreciated for the CP dimensions. If you have a Moonwalker PCB and all the bits, it's a pretty fun and collectible game. My cab is an HS5 which is basically the same cab, so it should work out ok. IF you need a PCB I do have a spare.
Just seeing if you managed to get those dimensions? I could really use them as I need to build a new CP pretty soon! Cheers!
My friend has a Moonwalker, I can ask him to measure. If he doesn't have the time, I'll be at his place the end of this week working on games and can do it.
Oh yes, and also @nerdygirl - can you take some photos of how the CP is attached? It appears this is a standard HS5 cab and I'm not clear how it attaches to the cab underneath. Thanks in advance!!!
the cabs you guys are showing is the non-deluxe model. They are just Dynamo HS-5 cabinets with the 4 player control panel and a 3 player coin door.
Yep, for me - that's preferred as I'm converting my HS5 to MW. So that's what I was aiming to confirm: 1) what are the dimensions of the 3 player CP and 2) how does it attach to the HS5 cab.
Thx
Just bumping this to see if anyone has any info they are kind enough to share. I am converting my HS5 to a MJ MW and am now at the final hurdle - to custom make a control panel. Not sure exactly what I should, or want to, do here. Has anyone else done the same - or better yet, have some dimenions.
I would also love some photos of the underside of the CP - I'm wondering if I can mount it directly on the dynamo CP or if I need to custom build an entirely new CP....
Necrobumping this thread in case something came out of it. I am helping a friend with restoring his dedicated Sega MJ Moonwalker cabinet after it has been horribly converted. He has everything needed except the three player control panel which from what I understand is different from the HS5 panels even though the cab is similar. He has the skills to make a replica, but he wants it to be as close as possible to the original control panel.
If somebody can please take some good detailed pictures of the control panel, both top and bottom and take some measurements it would be awesome! Thank you very much in advance.
I once saw a Moon Walker and a dedicated MERCS side by side sharing the same cabinet and control panel. My be another source to look.
