Missile command
baggdexpo
Ohio
Well I remember reading some where how to test the harness for bad wires,connectors.... What is a bad om reading? I know for a fact that the board works 100%... I know the AR, monitor and the power supply on the bottom also work 100%.... So that leaves only the harness.... So if I'm testing the wires for resistance .... What is acceptable and what readings is not.....thanks ....
Points between two end points (start and end) on sny wires should have very little rests car... Like less than 10 ohms
