Missile Command Trouble - board or not?
sleepygtr
hudson, Ohio
Need to know if anyone know if this is a PCB board issue...
I am having trouble with my missile command (regular cab) and the trackball pointer. Cursur rolls left and right, no problem but only goes up, not down. When the cursur gets to the top of the screen it blinks as if it is having draw-in issues. I took the optic boards off the trackball and swapped them to make sure it was not the board - these checked out fine - and with the swap - same problem. I tried the dipswitch setting with #4 on and off and no luck. Any ideas what I should do next? I also wanted to note 2 things: 1) I have a Braze Multigame installed that gave me trouble in the beginning, but i self tested and saved settings and never had an issue again and 2) I wanted to note that the game was left on for about 4 hours before this started happening. Vert hold went crazy, I fixed that with a simple monitor adjustment - and trackball issue started then too and is unresolved. HELP!!
