Missile Command to JAMMA
Solder
UK, United Kingdom
Couple of questions on hooking up a Missile Command board inside a JAMMA cab:
- Will a Centipede trackball work with a Missile Command board?
- What's the simplest (neatest, easiest) way to amplify the MC sound ? For example, does anyone produce a JAMMA adaptor for MC that has a built in sound amp? Or is there a better alternative?
centipede tb will work but smaller TB may affect gameplay.
I have not seen a MC to JAMMA adapter with amp commercially available.
Couple of options:
Build your own JAMMA adapter and either build or buy a small audio amp. You can hack a set of amplified PC speakers for the amp as well.
For my test bench I bought a Centipede jamma adapter with built-in amplifier then made an adapter to go from MC to centipede but that would be overkill for your application.
Bill
