Missile Command Sync
Fudd
Kalamazoo, Michigan
is missile command positive sync? is this how i wire it? i am not familiar with the different syncs. right now all i have is a green image on screen and a known good g07 chassis. and a unknown issue if the pcb is working or not.
R
G
B
G
+V
+H
3pin
none
none
none
If you can't coin it up and hear the game play, then odds are the PCB isn't running. Check the ROM chip sockets. Usually it gives a solid color screen when it's not running.
I think that's right per the schematic and wiring diagram. I made a JAMMA adapter for MC to test boards, and I think I had to set it for positive sync to test properly...
