Missile Command Power Brick wiring help -- blowing fuses
Do I have the wires hooked up properly here? The positive side is going to the molex connector while the negative side appears to be going into the ISO transformer. Is this correct? I blew F4 and F5 when trying to power it up after rebuilding the A/R II and replacing the big blue.
Any guidance?
Any guidance?
