Missile Command on the ArcadeShop Multi board
pacray
Erie, Colorado
Could someone speak to Missile Command on the Arcadeshop Multigame board?
Is it fairly authentic?
Does it work well without a trackball?
Does it work well with a trackball?
Do you need to have 3 buttons, or will it work with 1 or 2?
Thanks!
I've only played the vertical version but I like it... but it pretty much requires a trackball. No trackball = the suck.
It will work with 2 buttons, but again, it sort of sucks. The left and right bases fire then when one runs out the middle base will fire... though I think you can adjust that setting to choose which ever base you want to fire last. I've never tried it with 1 button but it's gotta suck.
I second that it sucks w/o trackball....
Also, If you care about authenticity - 3 buttons is the way to go
