Missile Command Dimensions
TissueLint
Donor 2025
Tuscaloosa, Alabama
Hey guys,
I am working with a company to make a replacement back door for my missile command upright cabinet, however since my back door is in pretty rough shape it's hard to get an exact dimension of what it is supposed to be. Anyone have a missile command upright they can take a height & width dimension on the back door to help me out?
Thanks in advance!
Don't you have the cabinet? Why can't you just measure the opening? If you still have the original back door (beat up or not) it should give you an idea of how it was built and held in place.
I do, I was just trying to get the dimension from someone so I can go ahead and place the order. I'm at work currently otherwise i'd just take the measurement.
This link is to drawings of all the wood components. There are free programs that will read the .dxf file format. Based on the drawing, the back door is 35.8125" or 35 13/16" x 23.6875" or 23 11/16" . The lock hole is .75" or 3/4 and it is centered left and right, and it is .3125" or 5/16" from the top of the door to the top of the .75" or 3/4" lock opening. It is .6875" from the top to the center of the .75" or 3/4 keyhole.
https://www.classicarcadecabinets.com/missile-command.html
Thank you for this. Sorry for the super late reply. I've been super busy.
which set of demensions did you go with. this is great. my back door is kind of messed up in parts
If you email them they will cut it however you want. The dimensions above are more accurate than mine were. I didn't see that post before I ordered my door. If you do email them I would make sure that they know to package it well (styrofoam or something on the corners) My first one came in damaged but they sent out a second one out no questions asked when I emailed them about it. Still waiting on the replacement door to get delivered.
My measurements were within 1/16th of an inch from the accurate measurements. My cabinet is a little bit off though and i'm not sure why, but it fit well enough for me to be happy with it. I'm also not sure if they can cut the keyhole for the lock as I didn't ask them to, i'm sure they probably would be able to though.
