Missile Command Cocktail Questions
Samelak
Oklahoma
Does the cocktail version of Missile Command use a different PCB than the upright version? I checked the dipswitch settings on the KLOV and did not see a cocktail/upright setting. Also, are there any different cocktail games that share the same wire harness? I am already finding it hard to find parts for this cabinet.
The cocktail uses the same pcb as the upright. There is a pin that is grounded on the edge connector that makes it cocktail. Early rom versions did not support cocktail flipping, so check and see what rom version you have. I think -02 and higher had cocktail support.
Brian
It's not that it uses a different PCB than the upright, it's that there's an "early" version of the PCB that has 11 EPROMS in it that doesn't work with the cocktail version.
If you're looking for a board to work in the cocktail, the later version with the 6 EPROMS will do the trick.
