Michael Roma
Time for an update...
I had someone look at the board and it turned out that D7 had a couple of broken traces. They replaced the socket, fixed the traces and the game had HSYNC again.
I got the board back, put it in and powered it on. I could see the MISSILE COMMAND screen but it constantly reset. I pulled the Big Blue and put the old one back in to no avail. I power cycled the game several times and the HSYNC issue came back. I left the game powered on, resetting while I checked something and when I came back to the front the game was going thru its attract mode and looked normal. I played a few games and everything seemed fine. I power cycled the game and it started resetting again with HSYNC off.
I replaced the Big Blue with one from Bob Roberts as well as did a ARII repair kit (caps/resistor/transistors) but still have the same reset issue. Sometimes the HSYNC is off, other times it is not and I can see the MISSILE COMMAND title.
Voltages at the TPs on the main PCB are are +5.13V, +11.78V and -5.14V.
Also, my power brick does not have a normal looking (to me at least) bridge rectifier like other Atari power bricks I have seen (see below). I am assuming this PCB is its equivalent. Do these fail?
- Mike
- Mike
