Mismatched sprites/images on Crystal Castles
I think I have a working CC board if your interested, if I do it's guaranteed to work when you receive it. if your interested PM me.
-brian
Replace the sockets on the gfx ROMs, or maybe swap out 7A.
It's something simple in the addressing.
Another bullseye for HudsonArcade.
I fixed a CC board this weekend that was pretty jacked up. Most time was spent fixing the missing pads and ripped up traces under the EPROM sockets that someone apparently pried off with a sharpened wood chisel or something. Maybe they just skipped the whole desoldering step?? Dunno. Please take brzezicki's advice and be careful with removing chips on that board. Those pads and traces are easy to lift / break. I would suggest clipping the legs off the chip and desolder one pin at a time.
Anyway, once I got the board to boot up, I had nearly the identical graphics issue where some motion objects were being drawn together, scrambled, or missing. I swapped out the LS374 @ 7A and it rectified that issue.
Good luck to you, and thank you for the tip Hudson.
