SOLD - PARTS Misc Joystick Lot, Top Fire Joysticks & Tron Spinner
Jano18
Donor 2020, 2023
Microswitch Button Lot (Large Flat Rate Box)
These were acquired through bulk deals. Some new, mostly used. What you see is what you get. (Sold)
Knock-Off Wico Joystick Lot (Medium Flat Rate Box)
Some of these parts can be used on 1/4" Skinny Wico's if you are missing pieces. (Sold)
12 Top-Fire Joystick Lot (Medium Flat Rate Box)
Used on games like Ninja Gaiden, Silk Worm, etc.
Random Lot of Joysticks & Shafts Lot (Large Flat Rate Box)
It looks like a DECO joystick, part of an Exidy and some random stuff that may be of use to someone possibly for parts.
Tron/Two Tigers Spinner w/o Opto
Pretty sure the shiny blue shaft and the base at the bottom are parts from a Super Joystick' by a company called PAL industries. Couldn't tell you for sure about the base as nobody has been able to come up with a complete example of one.
Good stuff here regardless.
Interesting. I can pull it out and supply more pics.
Micro Switch Buttons - Pending Local Pickup
Knock-Off Wico's - Sold
Interesting. I can pull it out and send supply more pics.
If you could that would be great. I know there is a red shaft on ebay right now but there are no good pictures of the base. I'm still not entirely sure that is the correct base for them but it does not appear to be a standard Happ/IL base.
Here's a few pics of that joystick
Thanks. both the shaft and base are definitely PAL super joystick parts. I created a photo gallery of what little PAL stuff i've found over the years. it isn't much but it lines up with the pics you posted.
Top Fire Joystick Lot, Random Joystick Lot & Tron Spinner are still available.
Make me an offer and I am always open to trades…
