MILLIPEDE: works but test mode will not come up
BBQ
Philadelphia, Pennsylvania
My Millipede is working fine (with Multipede board installed), however, I am unable to get TEST mode to come up, thus I cannot enter the settings for Multipede. Likewise, the alt coin switch isn't working either.
Any thoughts? I am going to dig into the wiring later today but thought I would throw it out there if anyone else had ever experienced this situation.
TIA - Scott
Bad ground on the switch plate. Trace and verify the connections are good
to the switch. There is also a test point you can ground on the pcb
to get to test mode.
Also check and clean edge connectors to the pcb.
