Millipede Wont Turn On
PJ
Delaware
Hello
I am new to this forum.
I have an Atari Millipede arcade game that I had moved to a new house and now when I turn it on I get nothing.
I do not know anything about these except I have had this one for over 15 years with no problems.
Is there something I can check on the machine that might have jarred loose during the move?.
Any asistance would be appreciated.
Thank You
Paul
break out a volt meter and check out the power supply and any loose connection to the monitor and game board set. Monitor neck board could have loosened up
Also there are voltage test points on the AR-II board (The vertical one with the large heat sink in the middle) that you can measure voltages from.
