chris25810
Millipede control panel, marquee, spkr. grille and manual set
Here's the catch with these: This cabinet was converted so the marquee assembly has a nother plastic marquee bolted over the top of the original. The control panel has a button hole drilled in it as well as other bolt holes drilled to keep the conversion plexi in place. Both of these pieces are going to need fill work but if you have nothing, it's a start.
The millipede manual is very nice and comes with a schematic set and other crap. Send a pm if you are interested in anything.
