Millipede cocktail in an upright?
push600
sunbury, Ohio
Does anyone know how to set a millipede board to "upright'" mode? The screen flips for player two. I looked up the dips and it doesen't say anything about those settings.
Game is in cocktail mode, how do I change this?
Centipede and Millipede do not have a cocktail DIP switch like some games do. Instead, Atari used a pin on the harness to determine upright versus cocktail mode. For millipede, this is pin 16. Millipede pin 16 should be left open (high) for upright, or grounded (low) for cocktail. This is backwards from how centipede does it. So if you are using some sort of centipede to millipede adapter or have rewired your harness, check that pin 16 is properly setup.
