Millipede bench test
mixinguiness
New Hampshire
Hey all, I am trying to test a Millipede on the bench and I notice that it has tabs for a 10.3V and +22/-22V. Are these needed to bench test? I have it setup with just 5V and monitor outputs and I am just getting garbage.
TIA
Any quick troubleshooting tips? I am getting a blank screen after hooking up 12V to the 10.3 line. I was getting garbage before. I have tried reseating all chips, and checked all my work replacing M4 (Originally had 6 beeps)
Are you using an adapter? I built one for Millipede myself which works fine..
No adapter. Just hooking up to my bench made switcher and an old Amiga Monitor.
So far I am getting garbage on half the screen, the only time it will change is if I ground the wddis post before turning on power. Then I get a full screen of garbage. FWIW its always blue.
Thoughts?
