Mike Tyson Punchout Playchoice
rcaido
Olympia, Washington
So i've been getting pretty good times in beating a lot of characters but for some reason my time score always resets when the power is turned off. I thought its suppose to keep your record...
Have you tried replacing the battery on the Mike Tyson's PO game pcb? It's probably dead.
If I understand this correctly a PC 10 chip is mostly the same as the corresponding NES home game. Mike Tyson's Punchout on NES uses a password system to save your record so if you can jot down the password you can still be 20-0 or whatever. It's been awhile since I fired up my home copy but that's the only scoring I can remember.
The Playchoice version is different. It can use the NES passwords but also has a battery to store and display the best times for defeating each boxer. You get to input your initials at the beginning of the game just for this purpose.
Thanks guys, i checked & there was no battery in the PCB...I guess last question, what kind of battery do i buy? If the battery dies, will i lose my time score again?
CR2032 is the battery you need. It's just a watch battery.
It should last you a long while, but when the battery dies that means no more scores saved.
