FS Parts: Mike Doyle multi pac 96 in 1 $45 plus shipping
I love seeing stuff like this pop up a couple days after I bought mine.
Probably a dumb question, but will my Pacman board with this kit the 96-1 work in my Ms. Pacman cabinet? Or do they only work in Pacman machines?? thx
Read a little it will work. :
https://docs.google.com/document/d/1JDyihPaXkt9TcJ_pQ62BjENT5DD3KWEwJPQAFJ9vMZ8/edit?hl=en_US&pli=1 said:
Decide which board you have: The Multi-Pac supports a variety of boards which are covered on page 8 of the manual. For Ms Pac and Pac begin at Step 1, for others refer to page 8
titled: Multi-Pac Manual Addendum: Installation on boards besides Midway
I think you have to convert to Pacman, then fit the kit.
I did this 4 years ago, so could be wrong. I think MS Pac has 2 x roms that Pacman does not, but All proms are removed anyway
Not true. You remove the 4 eproms in row 6, and the 2 eproms in row 5. Either a Ms Pac-Man or Pac-Man board will work with the standard 96-in-1 kit just fine. In the case of the Ms Pac board, you also remove the daughtercard from the equation too, seating the Z80 directly into the 96-in-1 main board.
This kit is the best one out there to date. I love it. It's missing only ONE feature that I hope to see implemented soon - a 'boot to THIS game' option.
There is a third version of the kit available which is v2.54Eyes. Since the "96 in 1" supports several boards besides Midway boards, you can install it on boards running "Eyes" encryption like some versions of Pac3 bootlegs or Eyes boards. At will also work on Make Trax, Pac1/Pac2, Falcon, Piranha, and Crush Roller. There is also a jumper included that you can move from one pair of pins to another to instantly support either the 25xx or 27xx family of ROMs that happen to be on whichever board you're installing the kit on.
Not a dumb question at all; the 96 in 1 will work on your board and you don't need any of the original ROMs or the daughtercard. The 96 in 1 plugs into socket 5E and the 40 pin Z80 socket and that's it, nice and simple.
Here's a list of boards supported by the 96 in 1:
Pacman
Ms Pacman
Pac1/Pac2
Falcon also known as Pac3
Make Trax
Eyes
Piranha
Crush Roller
You can install the 96 in 1 on any of those boards and the manual includes an addendum with details on each one.
It's a great kit! I just bought one last week, and I had it installed in about 15 mins. (Well plus another 15 for the wood, etc...)
There is a smaller satellite board that you have to figure out what to do with, as it is not the same size as the original. I did not want to modify the old mount so I cut a wood square and attached it with screws from the back side, PCB feet on the satellite board, and mounted it to the wood square. Makes it easy to remove and put back IF you decided to...
-Mike
attachment.php
