Midway Space Encounters - Freeplay Mod ROM Patches
SNESNESCUBE64
Michigan
I've been working on a midway space encounters lately so I decided I wanted freeplay since most of my other games are. This seems to be working just fine in both MAME and on my machine and I haven't noticed any side effects. Just make sure the dip settings are 1 coin 1 credit. Attached are some screen shots and the patch files. You can make the patched ROMs using what is out there for MAME and Lunar IPS. I am gonna try to remove the credit text at some point, but I am out of time for it right now. My machine still has issues, so let me know if you encounter any weirdness or need help.
If you get stuck or need reference photos I may be able to help. Mine is intact and I was able to get it running well. Still need to go through the monitor and install a fresh set of capacitors but it is playable as is. I have a spare MPU but it still has issues that I need to work through. I had picked up that extra boardset and something definitely bad happed to it. Ended up that 12 out of the 16 RAM chips were bad. I expect more bad chips but set it off to the side after I got my original boards running. I used a RED LED bulb for the effects and happy with the results.
Do you have the monitor gel for yours? I'm missing that and hope that someone does a repro someday.
Nope. Thats the only thing I am missing (other than the shroud, which is in Indiana with the person I got this from). The main board and daughterboard are working just fine as of right now. I worked on the sound board today and successfully got back all the sounds working. One thing I noticed is that it plays the player shooting sounds and one other (it's slipping my mind) during the attract mode. I am assuming that is not correct so I will be investigating tomorrow. The monitor chassis was filthy so I washed it and it is currently drying off.
