FrizzleFried Well-known member Donor 2011 VAPS Joined Mar 20, 2007 Messages 54,193 Reaction score 5,245 Location NAMPA, Idaho Jun 3, 2012 #1 I have an NHL OPEN ICE... can I drop a blitz 99 in plug n play?
tbbk Well-known member VAPS Joined Oct 30, 2001 Messages 15,402 Reaction score 109 Location Missouri Jun 3, 2012 #2 Blitz has 49-way optical sticks and I do believe Open Ice has 8-way sticks.
Broodwich Well-known member Donor 6 years: 2012-2013, 2015, 2020, 2023-2024 VAPS Joined Feb 20, 2011 Messages 9,846 Reaction score 420 Location Albany, New York Jun 3, 2012 #3 Yes you can, there's a dipswitch for using 8way sticks instead of 49way, you might have to mess w/ another dip or two for changing from med/std res. bank2 switch 1 for the sticks (8 way is off, 49 is on i believe))
JC Arcade Well-known member Joined Oct 30, 2006 Messages 2,598 Reaction score 58 Location New Jersey Jun 3, 2012 #4 I think some of the Blitz games had a dipswitch setting for 8 way sticks. Last edited: Jun 3, 2012
tbbk Well-known member VAPS Joined Oct 30, 2001 Messages 15,402 Reaction score 109 Location Missouri Jun 3, 2012 #5 Nice, I didn't know that. Broodwich said: Yes you can, there's a dipswitch for using 8way sticks instead of 49way, you might have to mess w/ another dip or two for changing from med/std res. Click to expand...
Broodwich Well-known member Donor 6 years: 2012-2013, 2015, 2020, 2023-2024 VAPS Joined Feb 20, 2011 Messages 9,846 Reaction score 420 Location Albany, New York Jun 3, 2012 #6 tbbk said: Nice, I didn't know that. Click to expand... i had to double check with the manual, i was pretty sure but not positive. link to the kit manual if you'd like: http://www.crazykong.com/manuals/NFLBlitz.man.pdf Last edited: Jun 3, 2012
OP OP FrizzleFried Well-known member Donor 2011 VAPS Joined Mar 20, 2007 Messages 54,193 Reaction score 5,245 Location NAMPA, Idaho Jun 3, 2012 #7 What's a `99 going for these days? Full setup with hard drive?
tbbk Well-known member VAPS Joined Oct 30, 2001 Messages 15,402 Reaction score 109 Location Missouri Jun 3, 2012 #8 Probably quite a bit less than if it was common knowledge you could run it without $250 worth of optical joysticks. FrizzleFried said: What's a `99 going for these days? Full setup with hard drive? Click to expand...
