MonsterBash
Specifically 80-904D (Sea Wolf) and 90400-hooo (SID).
The reason I ask is the Sea Wolf had 8.5v on the 5v test point. I pulled the SID PS (working) and stuck it in the Sea Wolf and it blew the fuse. They look exactly the same.
I did test the Sea Wolf PS with no sound or main PCB..I wanted to make sure I did have a issue with power. Would plugging in the 2 board pull the PS down to the 5v range
The VR tested fine in the Sea Wolf
Edit: Sea Wolf on the top..SID on the bottom
Thanks!
Thanks!
