Midway Power Brick work for Timber?
viperpack
Toronto, Ontario
Hey guys i cleaned up this Midway brick from a Super Pacman barn find just wondering would this work in a Timber cabinet? If so what else would i need as I plan to buy the Arcadeshop switching power supply adapter
I would check the 12pin pinout between the normal suitcase for a timber vs this one used for Super Pacman/Burgertime/Bump and Jump. If you're using the Arcadeshop adapter it may work, but you would need to check what voltage is needed for audio.
Timber:
Super Pacman:
Tapper has the dual big capacitors. Not sure that one will work. Expect too pay around 250$ for the correct one
i have used one of these in a timber build before...you will have to follow pinouts and build an adapter but with the switching power supply you can make it work :)
