midway INVASION the abductor-clock chip replacement
tron guy
Super Moderator
Staff member
Donor 12 years: 2011, 2015-2025
Eureka, California
apparently this is the same board as MK4?
anyway, I need help to determine where the clock chip is and what to replace it with. (if possible)
what makes you think the clock chip is the problem?
In test mode:
sound test says:GOOD
system test says : sounds GOOD
burn-in test: CLOCK ERROR 05
yellow led on the board while it's running is solid (should be flashing) indicates locked up
Your clock circuit is not going to be just a single IC. Find some schematics and take a look. Locate the crystal oscillator on the schematics and look at everything tied to it. Once you identify the parts you can start doing a real good visual inspection of the boards traces around those parts. I would do this before moving on to any real troubleshooting.
