Phetishboy
I am gonna try tackling this thing over the weekend and had a question. I assume these boards are supposed to have connectors at either end for the signal to pass through? Mine is hardwired/ soldered at both ends. I need to replace the chip, but can't remove the board without either removing the entire harness, desoldering all the wires from the header pins or cutting the wires off about 2-3 inches from each side of the board and adding in-line connectors. What would be the best way to do this? It seems several of the pins are tied together as well? What a mess.
