Midway Connector name/size
Phetishboy
Avon, Minnesota
I need both connectors that plug into the board stack for a GORF machine. The top two wafer connectors. What are they called so that I might order a couple from Bobby?
Not sure, count them. Dont forget to count the spot where the key is, if not you will be one short. On the housings it would be refereed to as "15 position" instead of 15 pin.
I think the biggest one I have in stock is 12 position. One of these days I need to do another big molex order before all this stuff is obsolete.
15 pin and a 10 pin?
It's a 28-pin and a 21-pin. 28's are really hard to find. You can usually pull the old pins out, cut them off, crimp new ones on, and reuse the housings (unless you've got IDC housings).
There's also a 9-pin .156 for the power input.
Edward
Edward
Was at work, no where near my machine and wanted to make an order there. I guessed wrong.
