irobot
Midway coin door wiring question.
I have a Ms. Pac upright and a Galaga upright
Both have nice coin doors with a lot of general hacking done to the door wiring.
I can read the schematics in the manual easy enough, but what I would like to do is fix the wiring exactly as it came from the factory.
For example, there are two different versions of the ms pac schematics, one shows multiple coin counters. It appears that the harness on my coin door had connections for both versions.
Also, some items are wired in parallel, but the logic of the wiring is not to be deduced because there is too much that has been cut away.
Does anybody have a schematic that shows the actual physical wire path in the doors?
