Midway 90411 Power Supply Cap Kit
gcpowers
Donor 3 years: 2015-2016, 2022
California
Does anyone but Bob Roberts sell a cap kit or rebuild kit for a Midway 90411 Power Supply?
i have most midway cap kits and rebuild kits. i do have a couple of them that are out of stock for a few weeks. all my kits have all axial caps and 105c which no one has ever had those. i should have the 90421 and 90427 kits out by the first of may with every electrolytic cap on the board that no one has ever had in their kits. you can search my site by just using those numbers or they are under the power supply kits menu category.
i didn't see a kit for the 90411 on your site but you do have most of the caps.
For the record a cap kit would consist of
All Axial
10,000uF 35 Volts
20,000uF 16 Volts
470uF 16 Volts
2,000uF 35 Volts
4700uF 25 Volts
Do you plan to carry the 2,000uF and when will the 10,000uF be in stock?
Thank you!
All Axial
10,000uF 35 Volts
20,000uF 16 Volts
470uF 16 Volts
2,000uF 35 Volts
4700uF 25 Volts
Thank you!
the 2000uf is upgraded to 2200uf. the 10,000uf 35v won't be back in stock for about 4-6 weeks.
