Metal cleaning/polishing
spanks_4
Denham springs, Louisiana
What is the best method for cleaning and polishing metal on the PF? I'm about to remove all of the metal bits from my spare LAH PF and just trying to find everything I need before I start.
OK, the hard-core guys pull all of the metal bits and run them through a tumbler which makes them like new. This is far beyond my current level. I'd consider that Level A.
My pinball buddy KenR does a lot of hand-polishing with a bench-mounted buffing wheel and rouge. This is also beyond what I usually do. I'd consider that Level B.
I usually just use emery cloth (green or red) and steel wool on the ball guides and any obvious corrosion. I just don't have the gumption to high-polish everything, just get it clean and smooth. Good enough for me. I'd consider that Level C.
That's my experience so far. Of course, I don't have any 3000-6000 dollar Tier A pinball machines yet either so...
I do the lockdown bar and rails with 800-grit wetsand paper by hand and take them over to Ken's for a final polish on the wheel.
RussMyers
I'm guessing KenR uses rouge and other compounds when he is polishing/buffing so maybe you can ask him how he cleans the dirt/crap off of the wheel so it doesn't just transfer dirt?
Mother's Mag Wheel polish, available from most auto suppliers (AutoZone, etc.). This stuff is WONDERFUL, takes off all tarnish, and leaves a bright finish. You can't go wrong with it. Funny part is, it's an effective pinball playfield cleaner as well. It REALLY goes after grime and tarnish, leaving a super clean surface.
Chris
Chris
+1 I use this as well.... Hand polish with the mothers, and then off to the buffing wheel. The guys games i shop are VERY, Very happy wit hthe results
