Those look pretty close to the same ones I bought (but mine aren't remote controlled), I don't see the ones I got on Amazon anymore, they were the 50 bulb version of these.
https://www.amazon.com/Ucharge-Chri...ring+Lights+18.7ft+50led+Indoor+String+Lights
I drilled the holes just a hair smaller than the base of the plastic bulb, I heated them up with a hair dryer as the plastic bulb is just siliconed onto the LED and they pulled right apart after they got hot enough. Then I pushed the plastic bulb into the hole of the sign and it being smaller, it held them in place and kind of threaded them in, I did put some silicone on the back side to keep them from moving, then just pushed the LED's into the bulb from the back side. PM if you have any more questions or need more pics. Thanks Todd
Thanks for the tip! I'll try heating them up.
