KaPH33n
I had a Nanao MS8-29FSG chassis that I received non-working. I fixed one of the problems where there was no h sync, but there was another problem where the blue was working intermittently. I found that there was a loose connection on one of the remote board cables. I decided to touch up all the solder joints for the connector, and while I was at it I touched up all the joints on the small vertical board next to it. I think this is what broke the chassis. Now all I get is white raster with retrace lines. The flyback screen control has no effect.
I may have fried the small vertical board while doing the joint reflows? Although, I didn't use extreme heat or anything. Was hoping someone else has seen this symptom. What I had before was fixable, but now I have no idea what to do. I may have to end up sending this off to a pro.
