Merit MegaTouch MAXX genius needed
melchman
Denville, New Jersey
I have tried swapping Hard Drives, I have swapped the Merit Daughter Card I have failed to locate a working motherboard. I am stuck.
The unit stops booting at "Setting clock..."
I have the two mother boards in picture two. Is there anything I can move from the parts board (left) to get the other board to set the @#$@#$ clock?
I have an older system (no hdd drive) but I did find lots of info here and look through it to see if it/they can help you with your problem.
http://www.meritind.com/Service Center/Technical.htm
