Merit Maxx trouble shooting
mrsodapop
Lawton, Michigan
I'm not sure if I'm in the right area for this post, but here goes. I got a Merit Maxx Jade edition that is DOA. Checked power supply-OK, monitor working good, can here hard drive spin up,no picture on monitor, and no sounds. Is there a website that has trouble shooting info, or is there some one on KLOV that could help narrow down problem?
Thanks for any info
Aaron
if you're not getting a boot screen at all it could very well be that you have bad caps on the motherboard. inspect them all and see if any are bulging or have orange goo coming out of them. if this is the case then your motherboard will need to be serviced.
I don't know if there's like a standard cap kit for these or not.
if the caps look ok, try hooking a regular computer monitor up to it. could be that you have a bad video signal cable going to the touchscreen.
Thanks for the ideas, There is no boot up screen,just nothing. I did try reseating connectors and Ram still nothing. Will check caps, and hooking up an external monitor.
Aaron
