Picked up a Merit Force 2007 upright LCD cabinet, and was working fine apart from a one area where the tape that holds the membrane onto the LCD screen, and adhesive residue had dripped inbetween both parts, carefully removed the touchscreen membrane albeit was held on with carriage bolts as the adhesive had literally melted off, and become a sticky mess, anyway cleaned that with the proper cleaner, glass clean, use the proper tape to restick the membrane to the LCD and now the calibration is way off, the green light on the touchscreen control box flashes when you touch the screen, anyone have any thoughts on this ? thanks
even thou when I run the calibration setup and press the center of the cross, once both crosses have been touched, it still seems likes its a few inches off
