I have a UMK3 but it seems that there is no button to get into the menu screen to change settings, diagnostic etc.. Can someone point me in the right direction on how I can add a button so I can get into the menu screen?
I'm assuming this is a conversion because the MK3 manual says to "press the test switch on the coin door" to enter the menu system but there is no test switch on the coin door. There is a yellow button that says "SERVICE" but when pressed it only inserts another coin.
I tried turning on DIP switch #8 but I didn't get to a menu screen.
I think it's supposed to go into the test menu when #8 is ON (on the sw bank #2), but maybe you need to boot it regularly, then try flipping the switch...
Well I tried it both ways, I am new at this though and don't have a lot of experience in this area. The Dip switches are the red boxes right? Anyway I guess I will try wiring in a new button in at pin #15. Thanks for the help.
