I have alot of arcades but recently picked up a fully functional megatouch xl upright and cannot wait to play it. However the touch screen is cracked. Anyone know where I can get one??? Any help would be greatly appreciated.
And be sure to make a note of the existing brand of touchscreen controller in your machine now. It will either be a "Microtouch" or an "ELO" brand. You must get the same touchscreen to match the controller or else you will need to get the controller too ($$$).
I had a similar issue when I moved the machine and degaussed the monitor. Ended up going away (fixed itself) the next day. Turn it off for about an hour and then turn it back on and leave it on for awhile, see if it improves.
Make sure your machine is plugged into a grounded outlet. When the machine isn't properly grounded the touchscreen double taps and it causes other erratic screen issues.
