Actually, the touch screen is taped close to the face of the tube. It can be tested by the diagnostic screens in the test menu to see if there is a problem. The controler is very reliable and is seperate of the actual touch screen itself. The screen can be damaged by scratches in the glass itself and most likely need to be replaced if one is found. Dirt on the screen can also affect the control of the touch and should be cleaned. Good luck....
