Megatouch Maxx help
davin72
Round Rock, Texas
So I just picked this up from a local Klov'r. When I picked it up it was fine got it home played for 2 minutes and Green went out. It was a smooth ride home so its not like something got knocked loose from that. I tried to adjust Green but nothing. I looked to make sure nothing came loose and everything looks fine. Is there something easy this may be that i might be over looking. Im sure the local guy will help me out but he and his family had a bunch of graduation parties to go to today. I know it doesnt make a difference but it is a Jade 2.
Davin
check you rgb cable to the monitor as its probably loose to the monitor board or a wire needs to be reseated on the connector
Im going to recheck that but now after playing it for a little bit its come up saying " This key is not compatible with this version" Not sure what happened there cause I was playing it even with the color out. I wouldnt think those two problems would be connected but Im not real familiar with these machines.
Well I reseated the key and now somehow i have green back and it recognized the key.
Ill just see how long this will last.
Is this an upright or countertop. I've seen this happen with a loose socket pin on the neckboard. If you lightly tilt the neckboard to the side, you may find you can make the color go in and out. If so, you can try bending the green pin on the tube slightly farther out from the center of the tube to make better contact. Use needlenose to make the slight bend, but don't break it off...
It is a countertop. I pulled the key out to make sure it was clean and making a good contact. While it was out I pushed down on the little bar that holds the key in so it would make a tighter fit and I think when I did that it might have pressed on the neck board to to fix the color. Right now its working like a charm. Im going to have to move it and just hope that I dont have to fix it again.
