Megatouch Ion - d945gclf2 motherboard - No sound
barakawins
Donor 2023
Woodcliff Lake, New Jersey
So I've have a megatouch ion that I finally got up and running after installing a
d945gclf2 motherboard. Everything works correctly aside from no sound. I checked the sound in the menu and it's up 1/2 way. Does the sound just come from the riser board to the
motherboard? Is there a dip switch on the riser board that needs to be set for sound? Not sure what's happening here.
Are you using the 3 pin headder on the motherboard or the speaker jack on the back of the board?
Try plugging headphones in.
I think if you use the 3 pin headder you have to change a jumper on the board.
status
So there is a Three pin header on the mother board. I tired the 3 pin header. However,
I wasn't getting any sound. The speaker jack from the I/O board to the mother board I
used as well. No sound. I"m wondering if I have to do something special to get the
speaker jack working. Also, you mentioned a jumper for the 3 pin. Do you know which
jumper and where it's positioned? I'll try headphones tonight.
Next to the 3 pin header you will see a Yellow pin header? maybe black... Are there Jumpers on it? If not you will not get any audio. There should be 2 jumpers on that header if you are not using the Front Audio (like the case header for Mic and headphones)
Here shows the jumpers
http://www.frontx.com/cpx110.html
update
It's nuts. It's the dumbest thing ever. I was working on an upright Ion fusion cabinet.
I didn't get anywhere with the jumpers. I drilled through the back door lock and what was there? The connector for the speakers!!!!!!!! Duh! It was not connected.
