Megatouch Force monitor issues
br549autosales
Donor 2012-2013
Foley, Alabama
I have a Megatouch Force 2006 model and the monitor is bright and not very clear and had diagonal lines on the screen. Is this in need of a cap kit or can I adjust this myself?
Thanks,
David
David
I would say, just turn the brightness down...
Alot of times you see the diagonal lines if your brightness is too high.
Then adjust the focus on the flyback.
Cap kits never hurt, (unless you do it wrong)
Steve
the lines you see are probablly retrace lines due to the overly bright picture you say you have. On the monitor chassis look for the screen control on the flyback....you will need to remove the hard drive to get a good look at the flyback controls on the chassis. Turn down the screen (turn conterclock wise) and watch the screen till it looks good to you. The black areas should look black and of course white should have a nice clean whiite look as well. Good luck....
