Megatouch Evo 2010.5 Manual and help needed
kuglerarcade
medina, Ohio
hi my brother just bought one of these megatouchs at the Ohio pinball show,and theirs a few things if anyone can help well 1,st is hes looking for a manual.the main issue is when your playing it and games over and you can put your name in it.the machine blacks out and then resets all over again.thanks everyone for your time in advance.
Try flipping dip switches 4&7 on the I/o board to do a factory reset. That usually fixes a lot of problems.
Is this a Force Evo (black) or Ion Evo (silver)? Manuals are easily available via a Google search.
The issue you're having sounds like a watchdog problem that automatically resets the game if it senses any sort of problem. You can disable it via dip switch 3. Otherwise, I'd first make sure that all fans are working as EVOs are known for heat issues that can cause major problems. Then I'd consider resetting everything as Spank mentioned. Down the road, you might consider swapping out the HDD and possibly upgrading to an SSD to help bulletproof things a bit.
Sounds like an issue with saving hi scores. Could be a corrupted hard drive.
If you start a game and end it without a score, does it still go blank? or does it drop back to the game menu?
