Megatouch Crown Monitor Problems
saturnkk
Commerce Twp, Michigan
Recently, my Megatouch (formerly a Jade I believe) Crown monitor starting having issues at start-up. At first, the dos boot screens looked like they were shaking but when it finally booted up, it dispalyed everything fine and worked. A few months later it is now displaying choppy white lines during the boot sequence and then when it finishes, the display is just bands of color. The screen seems to be working as it makes a tone when I touch it and the color bands change as the screen display changes but it never displays correctly.
1. I tried freeze spray over most of the circuit boards with little change other than the bands maybe getting a bit more colorful.
2. I tried leaving it on for awhile with no luck and then restarting with no luck.
3. I tried unplugging then replugging the power source, monitor touch connector and the monitor VGA connector with no luck
Any ideas? The led is solid green as well...
Thanks!!
Does the game play blind? Is this an upright or countertop cabinet?
Merit used a bunch of different makes & models of monitors in the Megatouch series. What is the particular make & model installed in yours?
