Megatouch Crown "Coin Jam" message?
br549autosales
Donor 2012-2013
Foley, Alabama
I have a Megatouch Crown game that i have set up for free play, but while the game is on, it will just stat flashing "coin jam" It will stop for awhile then it will do it again. Any ideas on how to fix this?
Thanks,
David
Bad I/O board. Try reseating the boards and see if it clears up. Might be a bad connection and it might work for a bit but if it reappears bad I/O. You can also unhook the coin door harness from the board to make sure it isn't in the mech but since I assume it has been on freeplay for years that shouldn't be the problem.
+1 to bad I/O board. Try the 'free' fixes first though.
