I have a megatouch game that when I power it up it beeps 4 times then 3 times and repeats that sequence, and will not come on completely. Does someone know what this means and how I can fix it?
Likely your ram is either bad or just needs re-seating. Luckily its just plain old PC100 which is a dime a dozen. I just had a unit with a bad stick of ram giving same beep code, after replacing it started up. This page has a wealth of info for your unit: http://www.meritind.com/Service Center/Technical.htm
I hope you are right, I will check it tomorrow. I thought that if it constantly beeped upon power up that meant it was either a bad memory stick or it needed re-seating. I think I rememb er reading somewhere that there was also sequence codes that meant different things that could be wrong in diagnostics. I'm banking on your answer though, wish me lick.
