You can use just about any monitor if you pick up a scan converter. For example upscan from EGA to VGA and use a PC monitor. I've seen old full motion Daytonas at D&B's all with large ~50 inch widescreen flat panels used to replace the horrible projection monitors.
There are a lot of cheap converters out there, but you should do some research because some have a reputation for not working very well.
Wade
