Medium Res Monitor on Paperboy
eb94110
San Francisco, California
I have a Paperboy that has always seemed to have the "jail bars" on its monitor, which has a 4900 chassis. I capped it a while back, and it really didn't do much. Recently, the flyback was changed. It has the same bars and also a strip of brighter color on the left side, which is not foldover.
Anyone have any ideas what to do to fix this?
Back down the Screen(brightness) on the flyback might help.
Rotate the game. If the strip of color changes it's a degauss issue. Try using a manual degauss ring. Could be you need to adjust purity or move the entire yoke a little to correct the color issue. Not for the faint of heart and I'd advise doing this with the monitor out of the cab and on a test bench set up using a TPG.
