Medium res monitor in a standard work?
78whiteorbs
North Carolina
Have an mk4 and a KI1 that had lcds installed...yuck. Trying to get back in the crt world .
Found a midway Cruisin USA for cheap with a great looking monitor but when I looked it up said the monitor for Cruisin USA is medium res. Is that a problem for mk4 or KI1? I know you can expect a standard res to work in a medium res but what about the other way around?
Was just reading and if it was a dual res monitor then I'd be good to go. WG U5000 I believe
not unless its a dual rez or a tri sync. there is the k7500 which is medium only. U5000 should be dual rez.. just keep in mind that crusin will badly burn the shield into the screen.
just because crusin should have a u5000 in it, does not mean it still does. an operator could have changed it. so check to be sure.
